The way Modern Technology and car trends are going the Future looks like combining the two:
Big Diameter Wheels with narrow Rim widths & Tyres, because they are more efficient and have the same footprint as smaller wheels with wider tyres.
No Wonder Classic car values are rocketing, car's will never be, look or drive the same again!
According to tyre-maker
Pirelli, instead of the squat, wide tyres we know today, the future is tall and skinny.
Because they face big challenges from tightening European laws covering the amount of noise and rolling resistance tyres generate.
The only way to work around the problem is to go tall and skinny.
The problem with tyres today is that they’re too wide, so they are terrible for noise and rolling resistance.
The solution long-term is for tyres to get taller and skinnier, which by making them taller you can make the footprint (the amount of area in contact with the road surface) narrow and long to keep it the same as the tyres today.
BMW is one of the first manufacturers to use the new breed of skinny tyres in a production car with its upcoming
i3 electric car.
When driving an BMW i3, especially for the first time, there is much bewilderment as to how it drives and performs so well with what seems like a monumental list of things working against it. Firstly, there’s the ride quality. It’s fitted with these short little shocks, it’s stiffly sprung and it has eco tyres, yet the i3 remains surprisingly supple over rough pavement. It can also handle extremely well, too, despite being quite tall and narrow, which is the exact opposite of the recipe for grippy handling.???
How does it manage to handle and ride so well when, by the looks of it, it has the worst possible recipe to do so? Well the answer lies in two parts, but it’s the second part that’s particularly interesting.
Firstly, weight has much to do with it. It's extremely light weighing less than a Ford Focus. This allows the
stiffly sprung suspension to handle any rough pavement with ease, as there is less mass moving about. This also helps in the
handling department, as well.
A lighter car is a more nimble car. It also helps that most of the weight is down low, in the floor of the car, where the batteries are.
At the front the BMW i3's wheels are 5" x 19" but the tyres are just 155mm wide, while the rears are 175mm wide.
The i3’s tire requirements were very specific. The tire needed to be narrow and have low rolling resistance , so as to be able to eek out as much range as possible. But narrow and eco-minded tires are terrible for both grip and comfort. So Bridgestone had to invent some new tricks to make these tires both eco-minded and grippy and comfortable. It was quite a task but that’s exactly what they did
The key lies in the size. The i3 is the only car on the market with this tire size of 155/70R19. The 155 is in reference to the width of the tire, which is 155 mm. The 70 is the aspect ratio of the tire which, long story short, means how large of a contact patch the tire has with the ground. And the 19 is the size of the wheel (an optional 20 inch is available), in inches, in which the tire fits to. At 155 mm wide, the i3’s tires are far narrower than anything else on the road. They’re motorcycle tire thin. But because they are so tall, sitting on 19s, and have a
large contact patch length-wise rather than width-wise,
" It allows the i3 to grip the road with a similar grip as a much wider tire."
Another benefit of having such skinny, lightweight tires on skinny, lightweight rims, is the lack of unsprung rotating mass. Unsprung mass is any mass that isn’t carried by the chassis of the vehicle, but attached to the outside of it. So brakes, wheels and tires are unsprung rotating mass. So reducing this helps the car ride better, grip better and handle better.
0 - 60 mph 7.3 seconds !
So Chris Harris 's video idea using 4 Space savers on an AMG 400+bhp car with surprising results was not so silly after all. It's not easy to understand a wider tyre does not mean more contact or grip but it is all factual.
Isn't it bizarre that over 100 years ago this big wheeled, skinny tyre electric car was designed by a guy called Mr.Porsche ! and now this concept is making a BIG comeback !
R
