Hilux
Before you all start, I have searched but have inconclusive data.
My front o/s pad squealed badly so I decide to investigate and check both front brakes as the car recently seemed harder to push out of the garage and also seemed to resist rolling on a slight downslope in neutral and brakes off.
`kin `ell, what a job. It took a whole day as the callipers suffer from `plate lift` and the pads were wedged in.
This meant that the pads were jammed in and were not relaxing properly (I reckon it was worth another couple of bhp at Weltmeister [
]) When I finally got them out the o/s squeeky one had transfered the inner pad material onto the lower part of the disc and the pad is indented at the bottom [
Last autumn JZM stated that the discs were nearing their limit. The discs have about 1mm wear each side.
To summarise, the pad deposits mean I need new discs and I`ll need to replace the pads.
I have spoken at length to people and I'm told the solid discs are fine and dont warp, drilled discs crack and warp etc etc
I feel that grooved solid discs are the way forward with better pads.
What combo`s are you all using bearing in mind I`m an ex Westfield/Ginetta track star so brake late and cooked them at Silverstone last time out.
I used to use EBC green stuff on my old kit cars but pagid and mintex keep coming up. The EBC`s used to wear out the discs (but discs are cheap) and were superb in lighter cars. What about Portefield as one 951 I tested when I was looking to buy had cross drilled discs with Porterfield pads and was superb.
