1) OPC technicians always use gold spanners !
2) I wrong about the stretch bolts [
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
] (my dad said I was wrong), but I think I'm right about the Loctite, you can tell by the colour of the bolt (blue coating) it used as thread locker to prevent the bolts from loosening, they use it because its more effectively than a locking washer (save cost ha ha), many of the bolts on the 986/996 have blue thread locker on them, thats why you should only use them once or just put your own Loctite on after cleaning the bolt thread.
Anti-seize is like copper grease thats makes it easier to remove the bolts, thats why you should NEVER put copper grease on your wheel nuts, I use Joining compound on the edges of my wheel bolts and the face of the wheel, this stops chemical reaction between the aluminium and steel parts.
3) This is how much I payed for my OPC brake parts:
986 351 401 05 Front disc £140.64 (2)
986 352 401 04 Rear disc £173.54 (2)
986 351 939 15 Front pads £67.95 (2)
986 352 939 10 Rear pads £64.16 (2)
999 067 041 09 Caliper bolts £10.88 (8)
986 612 365 00 Rear wear sensor £15.94 (2)
996 612 365 00 Front waer sensor £12.60 (2)
996 351 088 01 Damping plate £17.76 (2)
FUNNY - The Damping plate is not called up on the 2.7L !!!
But you will need them if you like your brakes silent and just love to hear the sweet engine sounds [8D] instead of the brake tapping each time you remove your foot off the brake pedal.
Total cost £503.47 (inc 10% discount) + vat = £591.58
Note. The above parts are for a 2003 2.7L (not 3.2 S) and the discs are not cross drilled (I hate drilled discs they crack and eat brake pads).
4) One big thing that helped my brakes, was when I replaced the brake fluid made a big difference even though the old fluid was clear.
5) Also worth a try is Berlyn Services (Independent supplier of Porsche parts)
http://partsforporsche.co.uk not sure if the brake discs are OPC ones.
Regards,
Chris.
