DIY Clutch on S2
When I got my S2 the clutch was juddery even though it had been replaced, according to the receipt in the paperwork, less than 5000 miles previously. It always juddered and I drove around the issue and took it to be a characteristic of the car.
Chaps,
Resurrecting a slightly old thread ... I recall a set of instructions which included some helpful hints of how to fit the crank sensor, and cutting the side of the casing away to make a C-shape thus making the measurement of the clearance a lot easier.
Does this sound familiar? Does anyone have a link to that guide?
Job is planned for a fortnights' time. Preliminary inspection is on Sunday ...
Thanks.
Removing a small piece of aluminium from 'behind' the sensor means the bellhousing can be replaced (and removed again) with the sensor in place. It is easy to space the sensor(s) with the bellhousing off, i found a washer of suitable thickness with a pair of calipers and then held it in the gap while adjusting the sensor.
Tony
