I have been changing my spark plugs since last week of January. All was well until I stripped the middle allen bolt holding the engine shroud onto the engine and then came weeks of hell trying to remove the bolt (see Rennlist link http://forums.rennlist.com/rennforums/showthread.php?t=412399).
If you are going to do the same I recommend that you push the three bottom spark plug leads out of the way first by sqeezing everything into the engine shroud through the oval opening, including the plug ends. Get a 6mm allen key and cut off the angled part with a Dremmel so that you have a long straight hex-key which you can insert into a 6mm socket, make sure you tap it into the hilt of the bolt socket with a hammer so that it is square onto the bolt and not squint (this is important) and use a ratchet and an extension bar to undo the bolt.
Maurice, do I get some spanners?
Harry
Harry
