Dual Port Wastegate
- Thread starter chrisdenton
Just buy a Bosch sensor if you have something to run it (there are probably only 2 or 3 types and they are all do the same). I have an Innovate setup and the sensor died (probably either run with the heater on and engine off, or engine on and heater off - best to wire it via the fuel pump relay so it can only run when the engine is running rather than via the ignition or a separate switch). The replacement cost about £100 from the local Bosch fuel systems agent.
sawood12
I've got an Innovate as well, and only got as far as having the bung welded in.
I don't know whether or not to bother with the piggy back right now. Can do without the extra expense and is a bit trickier to fit than the MAF kit. I guess on a standard turbo and engine Johns out-of-the-box settings will be fine. I think i'll leave the piggy back (and his new V-Flex system) for a later upgrade. I'd also be interested to see what changes the MAF kit makes on its own.
