Well, it's been an unexpectedly good day! I dropped the rear offside wheel off to have a look at things and noticed that the sensor connector wasn't properly seated. I pushed it in a bit and thought, 'I wonder?'. Quickly popped the keys in the ignition, started it and the ABS light went out, fantastic! I put the wheel back on and thought to myself, surely I can't be having that good a day? and took the car for a spin, the dash works perfectly and the spoiler deploys as should. I've never had a 30 second, zero cost fix before, I'm well chuffed! However, on the the next gremlin, the roof! The previous owner has disconnected both push rods from the roof mechanism as one of the plastic caps on the end has broken off. I've found one on ebay which seems cheap enough but I want to check that they are not 'handed'. http://www.ebay.co.uk/itm/111011603856?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 Also, I take it I will need to ensure everything is in the right place to connect the arms, is it difficult to set up?
