Hi, everyone anyone got any information to help. Thanks Kirk.
Engine Management light on, message underneath reads reduced power, ?
- Thread starter kirk.grannell
Hi Kirk,
The most efficient way to go is to hook-up some Porsche-specific diagnostics to find out what error codes have been flagged-up. Unless the car is under warranty, any reputable Porsche Independent will be able to help, and they’ll be much cheaper than the Porsche dealers.
987.2 boxster 2009, have hooked it up to basic diagnostic of my own, but no errors showing. Will try an independent.
Yes Kirk, you may need some Porsche-specific diagnostics [PIWIS or equivalent] to resolve the issue owing to the limitations of some more basic analysers. Often they will only pick-up emissions-related problems like lambda sensor failures.
Just some other thoughts. Have you recently fuelled the car [possible fuel contamination]? Is the fuel filler cap secure?
Good luck!
Good luck!
Kirk,
Any decent local garage should be able to diagnose the fault, generally this light is the result of an emissions issue. As Jeff says it could be fuel related. If it runs OK it could also be a dodgy sensor or connection or the emissions circuit. If it is running rough, suspect a coil that has died or a faulty Variocam control solenoid. There are diagnostic tools out there for £200+ that can diagnose all of the above. Examples are Foxwell NT range (I have an NT650 Elite which covers most marques and models) and an older Icarsoft PORII which is Porsche specific. Alternatively just go to any decent local garage and ask them to diagnose. If they deal with modern cars, they will have the capability to diagnose your fault without PIWIS. PIWIS can do much more, e.g. coding replacement electronic components to the car's CANBUS system but generally not necessary for most faults.
Thanks for the direction. Kirk. Going to start with the fuel, sure I can find someone I know with the equivalent or same, diagnostic tools as your Ian. Kirk.
Near Glasgow, not really any other symptoms, drove it hard today with fresh fuel, hardly if any noticable difference in power? But light still on. Kirk.
Too far away to help. There’s a code behind that light. Need to understand what is triggering it.
If you can’t get it to someone with diags with Porsche smarts then consider an icarsoft por v2 or v3 - or my personal preference a foxwell nt530. If you could buy from Amazon and then find that it didn’t suit your needs then you could return it - if you get my drift.
cheers.k
I would have thought that any diagnostic analyser would have thrown-up an emission-related issue [O2 sensor/cat], and you say that there don’t appear to be any ignition-related problems [plugs/coil packs].
I’d follow Paul’s advice, but one simple thing you could try is to clean the MAF sensor just to see if that has any impact on the problem.
Good point. You can disconnect the maf and the car will run with a default config - easy way to isolate a maf issue.
one thing. The 987.2 3.4 engine uses a MAP not a MAF - so any guidance you find about MAF may not directly apply if it’s a 3.4 (same basic principles apply - but they are physically different )
A wee update, at 80k, full service history. Boxster 987.2.2009. Today plugs, fuel and injectors tested. Suspected wear on 2 injectors, leading to some bore scoring, awaiting 2nd inverted camera to try and assess potential damage. Not accessible for finger nail test yet.
Some part specialists have advised modern fuel additives are to blame, causing wear to injectors. All 6 cylinders are showing uniform 16 bar pressure, which is encouraging. Have put in new fuel and additive to clean. Will post the pictures as we progress. Thanks to all for input. Regards, Kirk.
Great conclusion. Asked my tech to check the MAF and clean it. In doing so it was noticed the wiring harness had been chaffing for years against the block. Yep it wore through and under breaking etc, short circuited and send out the warning sensor. Have tested quite well in this great weather and after 3 days and 500 miles no repeat of issues. Interestingly we noticed some mild bore score, staining on pistons, and some un even wear on valve seats, through the inverted cameras. After research and feedback, and with 80k on the clock. With any Boxster engine design, some of the above issues seem common, happens a lot on Subaru Impreza's etc. As above the cylinder pressure is in accurate, there are 4 at 18 bar, and 2 at 17.5 approx. I think using the fuel additive is advisable regularly, as the two cylinders with slightly lower pressure, have slightly worn injectors, potentially due to fuel used. Which the fuel additive should help manage in the future. Best Kirk.
A bit of luck finding that chaffed cable Kirk, but a great result!
If yours is a 3.4L it’ll be the DFI engine, so the injectors probably will be under greater strain compared with the IDI setup on the 2.9L due to the high fuel pressures and - potentially - multiple injections during the inlet stroke. Other than using a fuel additive regularly, it could be worth sticking with quality fuels [Shell, Esso, etc.] which have specialised additives.
Hi Jeff, its the 2.9 but your probably right, I have just got a Porsche discount card for Esso, so will try and stick with that. Thanks Kirk.
