Having read the above I would suspect the likely suspect may be at the starter motor, and perhaps more than likely the solenoid. The clicking you hear could perhaps be either the relay that controls the solenoid or the solenoid it`s self..?
That you have replaced the earth leads and hopefully cleaned both ends where they connect to the engine chassis/gearbox or whatever to ensure good contact... and that the connections at the solenoid are not corroded or loose... A test perhaps worth trying to determine whether the issue might be battery or starter related, is to switch on the headlights, and try to start the engine.... If all you get is the click you mention, and the lights dim considerably then chances are that it is battery related.
If all you get is slight or no headlight dimming and hear the click when you turn the key to engage the starter, then the issue would seem to be starter related.
If starter related then the solenoid is perhaps favourite, The solenoid is just a heavy duty relay.
When you turn the ign key to engage the start sequence, that switching action then provides power to the coil of the first relay in the circuit, which will logically emit a click as it`s contacts close, those contacts when closed then pass on power to switch on the coil within the second relay in the form of the solenoid mounted on the side of the starter motor, it creates a louder click, with the coil in the solenoid now energised causing the starter motor`s gearwheel to engage the flywheel with a clunk, and once engaged the heavy duty contacts in the solenoid then close to make the starter motor live and turn the engine over
Thus a small relay switches on a larger relay which then switches on the starter motor..
The contacts in the solenoid can burn over time given the high degree of power that they are dealing with it is normal for them to fail intermittently over some time prior to total failure.. My thinking behind having the headlights on is to determine whether the contacts in the solenoid are passing current/power to the starter motor it`s self. In the case where the contacts have failed/burned and are passing no power and all you hear is the click you describe, the headlights are unlikely to dim to any great degree, as the load of the starter has not been switched through to the battery..
New solenoids can be bought independently of the starter, though if the starter has seen a lot of service it might be best to bight the bullet and buy a new or reconditioned unit..?
I have stripped and repaired a solenoid with burned contacts on a friends 928.. simple if you know how, though given the cost of buying a new solenoid, hardly worth the bother..
Hope this helps in some way.
Feel free to suggest where I might be mistaken,
