Engine Oil
ORIGINAL: 333pg333 but you won't find race cars using this weight oil,
No? Some use an even thinner oil http://www.eurotuner.com/news/eurp_0909_mobil_1_synthetic_racing_oil/index.html The W in 5W-40 indicates the oils winter abiility, W= Winter. The 5W is measure of how thick the oil is when cold (winter) usually down to -30. The 40 accounts for how thick or thin the oil is at working temperature. Edd
To "accurately" paraphrase myself...."but you won't find race cars using this weight oil, especially 944/951 race cars.". You clearly have your preferences. By all means use M1 5w/40. In fact why don't you use 0w/30 based on your logic? You obviously know better than people with a collective experience in real world applications of well over 50 years. So go for it. [:D] LOL Oh, and just by the by...there is no such thing as a totally 100% synthetic oil made for general car usage. They all have root stock derived from an organic compound.
at 100 degrees C a 20W40 has exactly the same viscosity and properties as a 0W40 5W40, 10W40, 15W40 etc. The higher the W rating the thicker the oil is at cold temperatures, the lower the number being thinner cold temp viscosity. Porsche obviously designed the engine to use an oil of around 40 viscosity at full operating temp and the reason for using a higher grade oil in warmer climates is because the viscosity of the oil decreases with temperature therefore in warmer climates and therefore higher oil temps you need to compensate for the thinning by increasing viscosity such that at operating temp you are achieving a viscosity of around 40. This is also true of race cars where the higher operating temps require a higher viscosity to compensate. At the end of the day modern cars use a 30 grade oil. Now when you've got two surfaces in contact and sliding past eachother then that situation is no different in a 944 engine vs a modern cars engine. Modern synthetic oils have developed such that a thinner oil can offer adequate lubrication between two sliding surfaces at a lower 30 viscosity without being 'squeezed' out from between the surfaces, so in a way a 944 might very well run perfectly happily on a modern fully synthetic 0w30 oil. If this is the case then the cars would benefit from lower drag due to the thinner oil, better flow of oil and more efficient cooling of the engine internals. I think the oil pump may be the only component here that might have a problem as oil pumps often require the fluid to have a certain viscosity to work. Would be nice if you could modify the oil pump to work with the lower viscosities.
Good points, well made. Its the operating temperature of the oil thats key which is why exceeding max oil temps is to avoided, however too thin an oil in a worn engine and the pump will not cope very quickly for the excess volume that passes drops the pressure. People do not realise how little pressure is needed at the crank to keep it all going for its volume, not pressure that counts as the oils secondary purpose at the crank is to remove heat (note the need for oil sprays also in some cars) and at the cams is more to lubricate although heat is generated. As for the start up benefits then I think we all need to stand back and consider what these engines managed on when running in when new. A completely different set of oil was available, primarily mineral and thicker than modern oils so I would err on the side of a thicker oil myself. Especially if the engine has a few miles on it. Modern engines are almost fully blueprinted with manufacturing tolerances manufacturers of yesteryear could only dream about and reserved for handbuild specialist engines hence they will thrive on lower viscosity oils with higher pump pressures to maintain volume and take heat away and consequently lower operating temperatures for longevity between changes. Summary, thicker wins it for me every time simply due to tolerances and wear for it promotes good pressure and volume. Gauges are notoriously inaccurate by the way unless you buy a good one with an accurate sender prefectly matched. The best are direct ie: wet fed to the gauge. Also if the gauge wasnt there and you only had a warning light then this thread wouldnt have taken place I`ll bet. Gauges create more to worry about. [:D] S`wat I say anyway................................discuss...............................[;)]
Mmm, I really don't think manufacturing tolerances come into it. The only reason why oil has to have any viscosity at all is to prevent it being squeezed out from between surfaces which are in contact and sliding past one another. There is no tolerance between surfaces that are in contact with one another no matter how old the engine, and if there is a clearance then there is no need for lubrication at all. The one and only benefit that viscosity brings to the party is to prevent the oil from being squeezed out - I think it is called shear strength or something like that, in all other respects viscosity is bad - it restricts flow, increases drag, it reduces cooling, it clogs up the engine as it breaks down with age and chemical attack and reduces efficiency. The reason why oils are thinner in modern cars is because oil technology has moved on and provided us with oils at lower viscosities with good shear properties. Cams and cranks havn't changed much in 20yrs - they're still case hardened, drop forged steel based alloys, but oil technologies have moved on significantly. I take back my comment about a 944 enigne probably being able to run on a modern 30 grade oil. A problem with this is that stable oil pressure, and therefore flow, might not be sustainable. Oil pressure isn't generated by the pump - it is generated by the rotation of the engine parts drawing the oil through the engine. The oil pump is basically a scavange pump to suck up oil from the sump and feed the engine. So at the design stages the engine's oil ways will have to have been designed with a specific oil viscosity in mind and if you go too thin then that will effect the way the oil is drawn through the engine and oil flow may be unstable and reduced - as it will if you go too thick. Our engines are thriving with many well into the 100k miles and some into 200k miles + with no engine rebuilds. Even the venerable air cooled 911 engines seem to need fairly regular rebuilds judging from the number of 911's for sale advertised as having had a rebuild at relatively low miles, so in anyones book that aint bad. Generally these things havn't been running on thicker than recommended oil grades and i'm sure alot of them have been abused with respect to the oil change interval at some stage in their pasts so i'm not even sure how sensitive the engines are to oil viscosities, within a reasonable band. I really don't think all this worry about oil viscosity is really that essential. Lets all just use decent quality oils at Porsche recommended oil grades and get on with our lives!!
??????????? Of course engines are built to tolerances. It is the tolerances that allow oil to pass through thereby ensuring direct contact between surfaces is avoided. Bearings and journals have agreed tolerances. Piston rings have tighter tolerances to avoid this instead relying on the oil film and smooth hardness to reduce friction.
??????????????????????? In which case the pressure reading would be a negative! There is no aspect of the engine that would create a negative (suction) pressure. Without head (positive) pressure the oil wouldn't travel anywhere. The only negative pressure in an engine is gravity. The forces upon a journal or bearing squish the oil out, without positive pressure it cannot be replenished.
ORIGINAL: 333pg333 Curious how significant the supposed charged particles in Magnatec cling to our Alusil cylinders? I'm in agreement with Thom. I wouldn't put a 10w/40 anywhere near my engine let alone a 5w/40. Remember that the Porsche manual recommends a mineral based Multigrade oil of 20w/50 down to below freezing temps (-10oC)...and this was on cars as recent as some 996 models. For those of you that really care about what you put in your engine, here is a most excellent and detailed thread that is relevant to our 'flat tappet' motors. One of the main contributors on this topic, Charles Navarro is a leading expert in this field. I have saved this thread and return to it semi regularly. [link=http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html]http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html[/link] http://tinyurl.com/yzrxn2t
Funny enough he recommends Added 9/22/2007 Valvoline VR-1 20W-50 -it is marked "Non-Street Legal".And that is what I run, in my 2.5N/A bought in 4 x 5L from my local guy it is 12.50GBP per 5L
ORIGINAL: Copperman05 I'm sure it is, they do a 10W-30 fully synth version too, or is that a typo? Edd
Nothing wrong with a 10w/30 in the correct or suitable applications. Just not on our Flat Tappet designed motors from the 80's. Funny how we were reading about a lot of advanced engine wear in UK 944s and 911s in British magazines a few years ago. Guess they must have all been using VR1 20w/50 and the thicker oil created a lot of premature engine wear.
Aussie sarcasm at its best mate [:D]. I agree I think a few ppl have made the mistake of running oils like the old 0w Mobil 1. The thing ppl don't understand about driving in the UK is that our climate is more or less irrelevant. If you live in or near one of the cities the car could be spending much of its life sat in traffic jams. I drove almost 3 hours in London traffic Friday last and the result was my car broke down from a heat related illness (burned plug lead for starters, may have overheated autobox). In these circumstances where the fan is constantly on/off for hours at end I bet the heat build up under the bonnet is far higher then blasting across the outback, AND with a decent amount of rpm on the motor at least the oil pressure is reasonable rather then spending hours bobbing around 2 or 3 bar. My dad drove busses for many years and he tells me they often had breakdowns caused by the transmission overheating in traffic. If you guys recall the reason I originally switched to Mobil 15w-50 was because I spent a lot of time in traffic (south coast + summer = traffic nightmare) and I was loosing to much oil on 10w-40 oil, switched to 15w-50 and the loss more or less went to 0. OK this is on a 150+K miles motor but then most of our cars are high mileage motors now.
I just switched my red turbo to 15/50 Mobil 1, oil consumption is much lower when driven hard,on the same trip to Germany and back it was at least halved compared to previous trip on 10/40..[:)]
Thats good if your saving money spent on oil but does having a thicker oil that gives less oil consumption actually a good thing, or does it just appear to be a good thing as less oil is being used? I mean is the thinker oil actually doing a better job than the thinner oil, or is just less of it being used? Why is less of it being used? Because its too thick to get burnt off as much as a thinner oil? Does that make it better at doing the job asked of it? Edd
Having had the head of my engine at various mileages and circa 100k hard miles (some on track with slicks / sticky treaded rubber) by me on top of the 90k it had when I bought it, I would say the thicker oil works fine right up until the point you wash it out of the bores with too much fuel - not sure the thinner oil would be any better in this respect however. Tony
ORIGINAL: MarkK I just switched my red turbo to 15/50 Mobil 1, oil consumption is much lower when driven hard,on the same trip to Germany and back it was at least halved compared to previous trip on 10/40..[:)]
Did you notice a change in the pressure as well? Tony
ORIGINAL: Copperman05 Thats good if your saving money spent on oil but does having a thicker oil that gives less oil consumption actually a good thing, or does it just appear to be a good thing as less oil is being used? I mean is the thinker oil actually doing a better job than the thinner oil, or is just less of it being used? Why is less of it being used? Because its too thick to get burnt off as much as a thinner oil? Does that make it better at doing the job asked of it? Edd
So oil being burnt off is a sign of superiority?
I think the key phrase in Marks post is 'Driven Hard'. When driven hard oil temps increase, viscosities decrease therefore the oil will thin. On 5w40 my old 944 hardly used a drop of oil for normal street driving - it would go between oil changes without needing a top up and use about half the distance between max and min on the dipstick. But on trackdays i'd be topping the oil up after every session on track (about 15 mins). Clearly if I was heavily tracking the car a higher grade of oil would be prudent. In anycase 15w50 is still within the Porsche recommended range.
Ah, the old 'thinner oil is better' comment. Stick 0W40 in a Mazda Rotary and see how long the engine lasts ;). I know in a 944 engine it doesn't help in the slightest. Although to be fair when my old engine had 0W40 in it (previous owner thought the engine had a stuck tappet) it did hold the oil pressure at 2.5bar when warm (driven for quite a while) and 5ish when on the run but as said gauges are not the most accurate of things in the world. It did however start to pee oil out of the crank seal not many months after it was put in, in addition to the lingering smell of oil. It's not about what's the thinnest but moreso about what is suited to the job in hand. In the case of some forum members here, they are from France and Australia, two relatively different climates when compared to the UK. Tolerances have more to do with things than people appreciate. In some of the rebuilt BL engines I've seen they seem to appreciate running more on a 20W50 than they do on a 15W40 (where the oil pressure gets lower than spec in even an Ivor Searle rebuilt engine with next to no miles). The Porsche is no different IMO (although I understand the pistons to bore tolerances are closer than people than people think). FWIW, I ran my last engine on 15W40 semi (it was on its last legs though) and my current one is on 10W40. I'm toying with going to 15W50 if I take up track days though.
ORIGINAL: 944Turbo Having had the head of my engine at various mileages and circa 100k hard miles (some on track with slicks / sticky treaded rubber) by me on top of the 90k it had when I bought it, I would say the thicker oil works fine right up until the point you wash it out of the bores with too much fuel - not sure the thinner oil would be any better in this respect however. Tony
Tony, why are you getting cylinder wash on the track? What a lot of people are missing (and this is from heavy traffic driving to track work) is that the oil is there not only to provide a lubricant and act as a coolant, but also to actually help prevent those expensive metal engine internals from colliding and destroying each other. As most of you would know the tolerances we are dealing with are sometimes % of fractions. Quite simply, having a higher weight oil that doesn't break down and get too thin under heat is offering greater protection than some of these very light weight oils that are being bandied about. Remember that the Porsche owner's manual right up to some 996's were recommending a 20w/50 mineral based oil amongst others. Sure some of the others would have been lighter weight 'synthetic' marketed oils but they are still given the option. Also we recognise that these oils won't give quite as good fuel economy as others, but again, that's something most Porsche owners wouldn't have at the top of their list of priorities.
Was mostly on the road and down to a faulty temp sensor, I knew it was running rich - well very rich, the black smoke was very visible in the rear view mirror, but at the time needed to do lots of miles quickly with little time to investigate. result was circa 170k miles with immaculate bores and around 15k to destroy one of them. Problem is now fixed but a little late. Will need to sort the engine soon, trying to decide whether to go with a standard unit or an audi TT V6, still havent measured one - though one of the articles here suggested it might bolt up to a 924 torque tube the 5cylinder does and I heard a rumour the V8 does. Dont know yet if the back end of a 924 torque tube will bolt up to a 944 gearbox, but imagine if not a hybrid tube is relatively easy. May decide just to get the original engine rebuilt, but either way need more time at home than I am currently managing.
