Further to my recent post 'engine dies momentarily'.
Things are getting much worse.
The engine cuts out in the following circumstances:
1. Starting from cold, after about half a mile, the engine cuts out. It will start again straight away, but will die either immediately or soon after. After doing this several times, it tends to be alright.
2. Starting when the engine is hot, e.g. after stopping to buy petrol. After about half a mile engine cuts out, again will start straight away again but will keeping cutting out 5 to 10 times before finally keeping going.
The last time I posted, the DME was suggested, I finally got round to changing this this morning (£17.10 + VAT from OPC including 10% PCGB discount), fully confident, the engine died as I turned onto the M4, in very heavy traffic and took many goes before it would run again without stopping. So, not the DME, unless I have a faulty one that is (It was date stamped a year ago).
I am waiting for JZ to get back to me, also does any one have Burt Gear's number handy, he is usually pretty helpful.
I'm hoping it will be some sensor somewhere, its spoiling my enjoyment [
] and I guess I must be putting a lot of strain on the starter motor and battery with the constant restarting required.
Any cheap/easy fix suggestions are welcome!!
I guess I will need to change my signature until it is fixed [&o]
