Engine Temperature Warning
- Thread starter kjhurley
Problem solved, one less thing to worry about.
Now, just got to keep an eye on those turbo chargers!
OPC warranty worth every penny.
Paul (formerly Road Runner)
Happy motoring from now on, its Targa time!
If you can't see any coolant dripping or leaking then it's likely to be just a void (air bubble) in the cooling system.
Apparently very common when changing out the pump.
I recall, I had to top up my coolant shortly after the pump was changed and had the same thought as you.
It's remained full since.
Having said that - just off to check now.
Very strange because I can see the fluid in the filler neck?
Perhaps the yellow dipstick is not very accurate?
I see your dipstick fitment at the bottom - Im guessing your's is as in my last post and just needs a top up.
[attachment=Untitled.jpg]
It’s going back to Silverstone tomorrow so they can check for anything untoward and top it back up while they sort the tracker. I’m going to ask them for a bottle of their Porsche Super Magic Coolant Fluid™? as well this time as well. I hear it’s from the Peckham Spring…
Good luck at Silverstone - it'll be a nice day out at least.
@design - probably worth getting yours bled as well if it's still under warranty.
Car back Saturday for a good old thrash.
Hope you have a great run out on Saturday. (-:
Keep an eye on the oil level too, Im only 1000 miles past last service and it took nearly a quart to top up to maximum.
Happy motoring from now on.
