Andy B Aces High
As you may have seen on another post on here I have two broken screws to get out, so the engine is coming out.
Made a start today, all the heater "gubbins" under the engine are off, and the rear under pan mounting cross bar. Engine and gearbox fluid drained, been round and checked that fasteners are going to come undone or squirted them with penetrating oil so that it is soaking in.
While it is out I plan to change all four rocker covers and gaskets, cam chain covers and gaskets, new rear engine/gearbox mount and buffer, power steering belt and cover, fan drive belts, catalytic converter heat shield, change gearbox lube, engine oil filters and oil. Will also check the clutch as I do not want to have to take it out again in the near future !
Next job, remove all the heater stuff in the engine bay, filter housing, exhaust boxes. Then label up all the electrical connections and disconnect.
Just need a good day weather wise this week and hopefully engine out in time for Easter.
Anyone else on here changed lower rocker covers before as I have fitted a new lower LH one before I started all this and the bolts appear to be leaking, do the bolts need thread sealer on them and if so what did you use?
Also anyone else on here taken their engine out and can point out any pitfalls before I fall into them ?
Cheers,
Andy B
Cheers,
Andy B
