Ok, I'm just summarizing the suggestions that I don't think has been tried, and if they have just ignore them. [
- Starter motor failed
- DME relay failed
- a short in the ignition circiut, check C2
- a short in the fuel pump circuit, check C4
- flywheel speed reference sensor or sensor mount failed
- idle speed control valve failed closed
- throttle valve stuck close
- resonance valve stuck open
These are all listed under 'enginge won't start but cranking normal/or slow' fault finding section. There's also a mention that an ECU fault is highly unlikely.
- DME relay failed
