FAN problems !!!!
- Thread starter guychris
sawood12
peanut
Well don't stick your fingers in the fan to give it a spin .!ORIGINAL: guychris
hi all, had a good long look today and popped the fuse back in, the whirring air noise began again although the actual fan was'nt spinning...mmmmmm!! could this still be the thermo switch?? or something else......
Sounds like the fan has come off the motor spindle ? make sure you are not hearing the heater fan as they are always on on a low setting when the ignition is switched on.Why don't you run it into your local garage for them to have a look. Won't cost anything for an opinion and the job ai'nt rocket -science
