Hi all,
I've got a few niggles with my Lux that I'm hoping you can help out with.
Firstly, just had the belts replaced by an indie specialist and now got a whining noise that increases with engine revs - was told by the indie that 944's have the belts tight so that the water pump runs properly - surely this can't be right.
And I can't see how to fit the rear wiper motor back onto the tailgate. I have 2x metal pins that stick out from the motor but nothing obvious for them to lock into. There are 3x brackets - 2x threaded and 1x slotted fitted to the tailgate - is something missing ?
Finally, before it went in for belts temp gauge used to run on 1st mark (about a quarter), I was told that the thermostat was missing and one was fitted with the new water pump. It now runs at just over 3 quarters on the guage and the fans cut in after stopping in trafic for about 5 mins. A replacement temp gauage sensor was fitted but made no difference. It is likely to be the guage itself or something else ?
Jeff
Jeff
