Hi All,
Last year I rescued a 944 2.7 from 5 years layup under a cover outside.
After 6 months renovation - the car was back on the road. With such a long layup - electrical problems were expected (and duly appeared). One persistent problem I have had trouble tracking down is the wash/wipe - and which has now caused me other problems. Here is the story:
Originally the water pump for the washers was faulty and this was changed - all OK
After a few months several wiper functions failed at the same time:
1) Wash and wipe, intermittent wipe and the first (slowest) wiper speed
I checked the wiring diagrams - but do find them hard to read. I did a couple of checks today and the following is noted:
a) No power to the water pump for the washers when I pull the switch
b) When checking power feed to the 'T' of the wiper relay - the 30amp fuse for the wipers blew (I had a multimeter between the T connection and earth)- again when the switch is pulled
c) When checking power feed to the wiper motor (connection no. 2) on the first wiper setting - the same fuse blew- when the switch is pulled
I removed the fuse board looking for any poor connections - found none.
Now - upon trying to restart the car - she initially fired - but I heard a loud click and then she wouldn;t start at all and the lovely "!" symbol lit on the dash.
Bypassing the DME relay (I have a spare direct feed to the fuel pump) - the car fired as usual - and I can energize the fuel pump relay by jumping the relevant connections as per Clark's garage.
So - here are my questions (and thanks for reading so far):
Q1) How likely is it I can have a failed DME relay just at this instance?
Q2) With the fuses blowing - I am getting power to the wiper relay and the wiper motor - but why are the fuses blowing when I try to insert my multimeter?
Q3) Any guidance on why I have lost the three wiper functions I noted at the start?
Q4) Are there any common points to account for the failed wash wipe/wiper/intermittent wiper function?
Thanks for reading!!!
Ian
(Car is 944 2.7 with Pro tuning chip)
Ian
