peanut
ok that makes sense. Right then... It is clear that the ECU is not earthing terminal 85b thereby energising the second relay in the DME (fuel pump) By taking terminal 85b to earth you are effectively bypassing the ECU earth and directly energising the second relay of the DME. You achieve the same result when you put the 3x way bypass in, which takes the +12v on terminal 30 and supplies it directly to terminals 87 and 87b thus supplying the ECU ,injectors and fuel pump without either of the DME relays working. Why isn't the ECU earthing the second DME relay ? mmmm well it has to be because either the ECU isn't receiving the +12v from terminal 87 of the DME relay or it must be because the ECU isn't receiving the necessary inputs from one or more of the sensors. Do you get a very slight twitch of the tacho when cranking the engine ? Have you cleaned the terminals in the electrical connector from the crankshaft sensor ? Have you tried getting someone to wiggle the sensor wire whilst you crank the engine ?
