Flywheel locking tool.
- Thread starter Frenchy
Hairyarse
This is US too - http://www.arnnworx.com/catalog/index.php?main_page=product_info&cPath=65&products_id=183&zenid=91532b0c63cedd64e2010631fe196cab
However low price may mean you don't get hit import duty - from memory you don't if it's under £35 but I could be wrong!
George Elliott
George
944t
J.C944TurboMan
No need to take the starter off .
vitesse
The ratio of the flywheel locking point radius to the possible slight offset of a crankpin at TDC leads me to conclude that the load on the piston will be rather large-& having used a extra long bar to undo & then some ,the crank bolt several times ,I'd avoid this method.
924nutter
As I thought. The piston material is malleable even when cold so considering the torque necessary to undo the crankshaft nut that is a stress that I would not put on the crown of the piston. It is not generally appreicated that an indentation could be put in the big end too. When we were torquing up beetle flywheels to 217 lb/ft we were told specifically not to use a flywheel lock but a peice of angle iron across two clutch studs, or we would put an indentation in the rear main bearing. The piston jammer does not spread the load out across all five main bearings but instead loads up one piston and one big end. I shudder at the thought like Sideshow Bob when he steps on all those rakes.ORIGINAL: robdimond
I really don't like the look of that 'alternative' lock that jams the piston in place. The torque required to undo the front bolt is quite significant... why take the risk of putting a hole in one of your pistons to save 15 mins removing the starter?
George Elliott
George Elliott
Frenchy, my young lad ordered one from arnnworx last week, its in transit. I got stuff from them years ago, no problems.
George
944t
Arrived Wednesday $35 all in. V. pleased
George
944t
Think about renting that out with a view to a deposit being able to recover a non returned item, will call OPC for a price the morrow.
