orangecurry
Just to add, after doing some research on the matter, the difference in tyre 'diameter' as the way the 4WD system works on the 993 is a complete red-herring. Data: Don't forget that as the tyres wear, the diameter will decrease by up to 14mm 225/40/18 = 637.2mm 285/30/18 = 628.2mm so with worn tyres, the difference will vary from 27mm to 0mm And the narrow bodied C4 is even less likely to be controlled by tyre-diameters, sitting on 265/35/18 = 642.7 So how will that achieve any drive to the front axle? So... what DOES generate CONSISTANTLY a 5% 'drive' to the front through the VC? Also apparently not the different ratios in the actual diffs on each axle, which are (according to the technical data in Porsche's own 993 repair manual) the drive ratio's front and rear being the same at 3.444:1
