Front Brake Disc Drilled Holes Filling With Crud
- Thread starter Gazoak
Steve Brookes
Moderator
Motorhead said:Chris,
After quite a few track day outings I can confirm that high rear pad brake wear does seem to occur, presumably due to the action of the PSM system. However, I can't recall having seen the PSM warning light flashing at any time while on track.
I must say that I was rather surprised when I discovered that the rear pads appeared to be worn more than the fronts when I checked, although if - as Kevan has pointed out - the rear pads are thinner than the fronts then perhaps the wear rates are very similar.
Jeff
When tracking my CR with PSM on in dry conditions the light never flashed. When I turned it off the light flashed on the exit of just about every corner! I've yet to work out what that means! My guesses are:
1. When off the PSM is not helping me but it's telling me I'm exceeding traction and grip.
or
2. When off and I've exceeded traction and grip the PSM decides it must intervene to help and lets me know that it is.
And when PSM is left on it continually does its thing to help but doesn't feel the need to tell me (hence the light doesn't flash).
Steve Brookes said:Motorhead said:Chris,
Jeff
or
Thanks Steve - some useful guesses there. When off I thought that PSM only intervenes when you brake or perhaps in extremis.
Generally I leave PSM on but will have to try turning it off next time out.
Jeff
"When you brake in the ABS controlled range, the vehicle is stabilised even when PSM is switched off. One-sided spinning of the wheels is prevented even with PSM switched off."
"When PSM Sport mode is active, it is only possible too switch to PSM OFF if the PSM was activated beforehand."
"PSM Sport should always be switched off during "normal driving".
In other words PSM is never truly OFF. The flashing of the PSM light warns the driver of PSM control functions taking place.
Brian
