Neil Haughey
Worth adding that since I went to x-drilled sebro disks (don't know if cast or drilled holes) I don't get the problems with the pads glazing that I used to get. I assume the pads used to glaze because if I used the car for commuting then after a couple of weeks I would feel a marked decrease in brake pedal feel and sharpness. After a couple of hard sort stops the brakes always came alive again but since fitting the x-drilled disks the problem never materialises in the first place.
BTW the sebro disks have chamfers around the holes which I believe you are supposed to monitor since when the disk wears down enough to not see the chamfers its time to replace the disks. Not sure what benefits the chamfers give though but they might help slow or limit cracking?
