Front radiator grills and OPC Warranty
- Thread starter Image
I answered that question on the other thread where you asked it, Keenan!ORIGINAL: KXJ 911Turbo
how much should one pay for an extended warranty? I have a 4 year old 997.2 turbo under factory warranty until 2015....do you know whether this can be longer and at what cost?
http://www.porscheclubgbforum.com/tm.asp?m=809684&mpage=2&key=
http://www.porsche.com/uk/accessoriesandservice/owningyourporsche/porschewarrantyperiods/
I suppose the warranty company argued that they normally get a rock through them (wear and tear) before they have the chance to corrode (warranty)......[8|]As above, it all depends on your PC.ORIGINAL: Boxstercol
although I have read a while ago about someone having an issue with an air con warranty claim when they were fitted.
Chris_in_the_UK
They may not care for something silly, but they very well may care for the big stuff and that's what you want the warranty for. You could fight it in court, but how deep are your pockets?
I don't disagree that it's completely common sense to fit the grills, but warranty isn't always common sense.
However they know my Turbo has a Bosch battery and when it came to warranty renewal time they were happy for me to swap the Bosch for a borrowed Porsche one to pass the checks?
Sometimes doesn't quite make sense?
paulbarlow
I raised this topic fairly recently in the 997 Members section - http://www.porscheclubgbforum.com/tm.asp?m=792545
Subsequently I asked my local Porsche Centre (Aberdeen) to see if they could come up with a definitive answer on the implications of fitting (in my case) Zunsport grills. This is their response.
Regards,
Paul
garyw
Moderator
I guess though that if you ask for an official response you'll get the 'official answer' straight back... they have no option but to do so.ORIGINAL: paulbarlow
Hi,
Regards,
Paul
Chris_in_the_UK
Warranty companies are notorious for wiggling out of stuff if they can. Our other car is a BMW X5, the extended warranty is BMW but in reality it is an insurance policy provided by somebody else.
I would take zero comfort in what any POC centre advises as to if it is acceptable or not since it is a hypothetical question until a claim occurs. If they can get the business for an extended warranty then they will do so.
Clearly a slightly cynical view............
ORIGINAL: garyw
Hi,
Regards,
Paul
Chris_in_the_UK
But when it's a home game for the warranty company I would expect it not to be a fair fight.
It's not about anything being 'injurious', the point is about modifications away from factory spec. for a given model.
ORIGINAL: Lancerlot
And if it came to argy-bargy, Porsche would need to explain why mesh is factory fitted to some units, yet is considered injurious in other derivatives of the same model. [8|]
Regards,
Clive.
