As above, the garage have just found out that the caliper is porous and leaking fluid, its my everyday transport and has been off the road for two weeks now. The mechanic is struggling to obtain this part as, apparently, its only fitted to the 86 Turbo model. Piston size 36 & 38mm. Am pretty sure its the nearside, but will update when I've found out for sure.
Alternatively, does anyone have a set of the later model front Turbo calipers as apparently these should substitute.
Thanks, Paul.
Thanks, Paul.
