944Turbo said:
So with aluminium arms you could retain the standard fixing method and use the 19mm pins I linked to earlier designed to fit them, or risk a mod with 17mm pins that might fail - Extended 17mm pins have failed ....
Yup I can confirm that [
And don't forget Peter's Brands hatch incident. Lowered suspension and high cornering forces around a tight corner took the original ball joint beyond its operating range causing failure.
Steve Kevlin, (Porsche Club Motorsport head and former 944 racing champion) is dead against lowering the suspension as Porsche did an extremely good job in designing the geometry in the first place and lowering just mucks it all up (as noted in the OP).
