James_G
Interesting, I have been looking at these [link=http://www.earls.co.uk/]http://www.earls.co.uk/[/link] but good to have another choice. The difficult part of this job, beyond negotiating all the various motor trade issues, seems to be how to effectively join a piece of flexible pipe to the existing solid fuel line. Earlier in this post somebody has said they've gone down the compression route, but reading elsewhere there's people saying you can't get a decent seal as compression joints are designed to work on softer materials (copper presumably rather than our steel lines). I agree that the nicest solution beyond wholesale original part replacement could be flexible pipes from the back all the way to the pipe joints at the front, which I believe are just before the original pipework heads into the engine bay, and I think this is what the RPM solution does. Meanwhile I spoke to my local independent about what they do and while they said doing it properly was the preferred option, they've seen plenty of cars running rubber fuel pipe and clips with no problems. Meanwhile here's the Rennbay option, and which seems to run compression fittings, but looks only long enough to replace the pipework over the rear trailing arm. [link=http://www.rennbay.com/fuel-hose-replacement-deluxe-kit-porsche-944-early-late-p-147.html?osCsid=1494c9327101c3b7417a8b4386cdbe87]http://www.rennbay.com/fuel-hose-replacement-deluxe-kit-porsche-944-early-late-p-147.html?osCsid=1494c9327101c3b7417a8b4386cdbe87[/link] Choice, choices....
