edh
Getting a car on 4 axle stands is fine - but you need to be careful to get them nice & solid. Take some time and you should be OK Leave the wheels on, jack still in place & you have a bit more protection.
The jacking point on the sills is the best place to lift the car - you can also use the gearbox, although some people don't like using this as it may damage the mount. Front crossmember is also an option, but usually this is covered by the undertrays.
If you're going to check the gearbox oil level, you might as well change it as well (Often ignored, but should be done every 15K I think). 17mm allen socket for the plugs (remove fill plug first)
