924Srr27l
Richair said:Roger I chose those spring rates for road use and the odd trackday and sprint; at the time I had no intention of doing what I've done to the car now!!At first I was apprehensive that they would knock my fillings out, but my research on what the yanks are up to suggested otherwise; they were right and I was pleasantly surprised at how good the ride is. Knackered old Koni's don't ride particularly well so most quality new suspension will be an improvement. The point I was making is it's all about the damper and spring rate package- firm(ish) spring rates with the right damper will ride well and be a much better car for it. I can point my car down the bumpiest of tight, twisty B-roads and never does it feel anywhere close to unaccountably harsh (and believe me I have paid good money for some very disappointing suspension kits and coilovers over the years that have ridden like crap even with modest spring rates...). The 944 is quite a heavy car in standard trim so it needs the spring rates to match in my opinion and its surprising what you can get away with! That is providing the dampers are a good match.
My car is being kept road legal, but I will be revising the suspension specifically for racing. I'll only use it occasionally on the road for the odd show or Sunday morning drive, so the next set up will be far more compromised! I was referring to the torsion bars in my post above. My front ARB is a 26mm and I run a 22mm Weltmeister adjustable rear, so everything is covered in that department. I could go bigger on the front, but I like my cars to be set up 'on the nose'. Eventually all the rubber will come out of the suspension and I plan on having the dampers re-valved, or swapping out to something else (although I like the billies a lot!).
I think it would help Rob out if he could possibly ride in some cars with different suspension set ups to see what he thinks feels right.
P.s. Roger I've just found your website, what a build!! Incidentally I've built a very similar front brake kit for mine using forged SL6 calipers...
Yes the 20 piston Braking system is quite Impressive! and then some..
Ok, but your Billy dampers can and could be used with the car's standard coil and torsion springs so they if anything are
far softer (being road valved) than your spring choices which are almost twice the original ?
That rear 22mm ARB is well stiff, and the front not that much ? A lot of racers and Roadies go (MO30) 30mm front bar and 18mm rear...
The 944 in general isn't regarded as a heavy car at all compared to other cars in the same era not to mention current.
A stock 952 (Right hand drive) is similar to my daily drive (Ford Focus 2.0 16v) 1400kg
My 924S 2.7 is 1030kg and is too stiff on 190Lbs fronts, the original car was on 140Lb Springs and weighed 1260kg
So I've increased the spring rate a lot relative to nearly a 20% lighter weight reduction and hence it needs to be trimmed
and the ride height raised a bit.
My front bar is 26.8 and rear 16mm, Rear Torsion bars 27mm Hollow Approx 200lbs rate. The rear is fine, has good compliance
and all 4 shocks are Spax Gas adjustable (Front Inserts & Rear Tele's) and I'm on Skinny 7J Rims and 205/55/16 Tyres (all round)
There's no under or oversteer or wheelspin issues, but it does not absorb dips and bumps well... it will not compress because the springs
are too hard on bump, it feels over sprung at the front and under damped, and even worst when I increase the damping as then it doesn't want to go down or up ! and is then just a washboard jarring ride......
I want a higher ride height Rallycross set up, with good travel and not a ground skimming Circuit race set up...for the UK roads.
R
