cobalt911
Hi all,
My car has a tendency to get annoying little faults! This one is the most annoying to date. It is 'holding on to the revs', which the only way I can describe it! It takes a while to settle to an 800rpm idle too but once there it is fine. When I change gear it is almost like I am pushing the clutch with my foot still on the throttle as it sits in the rev band a while before lowering. This is irritating as it a) sounds like you can't work a clutch and b) has the unfortunate effect of lurching the car forward on the remaining revs when in the higher gear.
Any thoughts? In the old days it sounds like a slightly sticky throttle cable or something but I am now guessing it is more complex than that ha ha. IT had a new ECU about 2 months ago as well.....
Thanks,
Mark
Thanks,
Mark
