szklarek
I'm back home and, as suggested, disconnected the battery for 10/15 mins to reset the ECU. Unfortunately this has made no difference.
So to date I've cleaned the ISV and 'reset' the ECU.
Over the past couple of days the problem seems to have got worse - the engine, on idle, now sits between 1100 & 2200 rpm - hunting between these two points; occasionally it will steady at around 1300 rpm. When idling it seems a bit rough although at much higher revs it seems to run OK.
Am I looking at an ECU failure or could the other items suggested such as the MAF, throttle position sensor (is this the same as the throttle relay?), vacuum leaks, O2 sensor be at fault? Before I get my credit card out and head for Northways is there anything else I can easily clean/check (where are these other items that I mentioned above?).
Kind regards
Anton
Kind regards
Anton
