Harness advice needed
Cheers Hugh. I will check later. The harnesses were not supplied with any split pins so that's not something I looked out for.
No, its odd, schroth dont supply but they are supposed to be fitted...belts and braces and all that. I've had scrutineers pick up on it in the past.
I've found the holes in the clips now Hugh! Hadn't spotted them until you mentioned it. Just need to find some split pins to drop and lose now [:D]
I too have been picked up by a scrutineer for the split pins.......can't see then actually having any benefit myself.
