Has anyone fitted 968 cooling ducts?
- Thread starter edh
Neil Haughey
Contrary to the often mistaking belief they do change the suspension geometry because from memory the ball joint sits at a different angle under the upright.
The one with a 951 number ISTR does not have the mounting tab at the front for cooling ducts.
IMHO the addition of 968 cooling ducts was the best upgrade I have made to my S2 by a country mile. Even on the road you can feel a big difference braking from high speed i.e. no fade.
Pretty easy to fit.
Neil Haughey
TTM
Well-known member
It really is easy to accomodate them on 944 wishbones, just need to use the screw of the ARB link.
PS : most if not all 968 part numbers begin with 944 ; most 968 TS specific parts begin with 968.
ORIGINAL: TTM
That's because it's the 944 S3 and inferior to the 951, which has always left me a bit perplexed as to why it has the track day icon status - a triumph of timing and marketing over substance methinks.
Diver944
http://www.promaxmotorsport.com/brake_cool_kit_951.htm
TTM
Well-known member
ORIGINAL: Fen
sawood12
ORIGINAL: Diver944
Another option is to fit the factory 944T M030 brake ducts that take air straight from the front PU and direct it onto the deflectors on the strut, as pictured here
I think my car already has these fitted. I think you can see them in my pre-big black install photo attached below....
Neil Haughey
Neil Haughey
Car magazines,,,, and the fact that most journo's seem to be oblivious to the fact that you can easilly replace the suspension if you don't like it or the brakes i.e. fit upgraded suspension to the S2 and you get 968 CS performance more or less and save £££££.ORIGINAL: Fen
ORIGINAL: TTM
Many similar reviews I recal slagging of the M3 CSL as a waste of money because a) the brakes go off b) ISTR lack of steering feel on cup tyres which to me is just code for an idiot that can't drive properly on high grip tyres and therefore needs bakalite tyres which you can squel about all other the place.
You can tell I don't care much for blooming car reviews.
