have have just got this report
- Thread starter Smunns
What model, age?
What is your question?
Ralph
I guess the the question for you is (if you are looking at buying) do you really want a car that has been driven "so enthusiastically"
If it is your car, fun at this level has a cost...
I read lots of over-rev data and what's important in the above is that the time stamp of the last range 4 over-rev was almost 1000 engine hours ago - about 30k miles ago. If that over-rev had caused an engine problem you would know by now.
The rule used to be within 6 months - to do more checks. This was essential for range 5 and 6 - range 4 was debatable.
KR Lee
We say that 5-20k ignitions in range 1 is normal for a car with 60k mikes. The upper end is the more enthusiastic driving end, but not driven hard. A car driven hard would be pegged at the limit, which is 65k ... which I have seen a few times.
From the engine hours above I'm going to assume you have covered about 42k miles +- 10%
Kind Regards Lee
Smunns
How do you work that out? It could go up through 3 quickly and hold at 4 for longer therefore it would show more revs in 4 than 3 []Geoff997 said:Something not right with that report. The reading for range 3 and 4 are identical, which is impossible. Rev range 3 count should always be higher than 4. Think I would get that reading checked independently.
Are you sure?? That would give false historical readings in the other ranges as they can't be doing all ranges at once. That doesn't sound logical or correct to me at all [&:]Geoff997 said:Because rev ranges 1,2,& 3 keep counting up while in range 4
range 3 363
range 4 209
which looks correct .
so clearly a miss shift and yes Porsche will not warranty a car with revs in range 3 unless you pay ££££ for bore checks etc.
I would forget the warranty cost, it's a 2011 car what have you claimed for so far ? and also any part ex going forward, Porsche cannot retail a rev range 3 car these days so they goto auction and all the main 3rd party dealers will not take that car in, sorry for the bad news.
your cars fine as it was ages ago, the issue is rev ranges now are a massive black mark in 3 and above, so people just say buy another, so not an easy thing to now ever sell.
Steve Brookes
Moderator
