headlight beep
- Thread starter nick9one1
nick9one1
basically, a relay is opened by 12v from the ignition, so when ignition is on relay is open.
the other 2 pins are connected to the sidelights and a buzzer.
So when ignition is on and headlights are on, relay is open. No buzz. When ignition is off and headlights are forgotten, the switch clozes and connects the headlight 12v to the buzzer.
My other idea was to connect the earth from buzzer into the door open switch earth, so will only beep when door is opened... but not sure quite which way round the door switch operates.
robwright
Alpine
ORIGINAL: Eldavo
It's been mentioned before that having the pods up is a pretty good reminder that the lights are on![]()
when my side lights are on my pods are down .......
nick9one1
ORIGINAL: robwright
Yeah it's a simple enough circuit alright. Most buzzers usually aftermarkets for this age of car use this kind of arrangement. I am sure they are available for what you could get the parts for and postage. Now if you could do one that only operates when the engine isn't running then that would be a little better []
I'm pretty sure that only works when the engine is switched off.. when the coil is energised from the switched ignition it breaks the contact between sidelights and buzzer. if the lights are on and ignition off 12v is supplied to the buzzer.
I think on early cars the pods come up when your only on sidelights, later cars they stay down.
nick9one1
so...
ign off, lights on, door open = buzzer on
ign on, lights on, door open = buzzer off
ign off, lights off, door open = buzzer off
ign off, lights on, door closed = buzzer off
think i'll atempt this in the morning, got a few spare relays.. so will just pick up a cheap buzzer from maplin -
cheap 12v buzzer
VanhireBoys
The drivers door switch is a 2 pole affair 968-613-601-00 if I am not mistaken
