Helmets
- Thread starter bennyboy
Once upon a time I may have bitten but - yeh, what ever you say. [8|]ORIGINAL: 944 man Sorry: on the very edge of the myth.
Neil Haughey
Good point, this is why I have been deliberating like mad about the roll cage for my S2 and will likely end up getting a custom built job, or rather a variation on an existing product. I have decided one has to have the dash bar due, for a start the 944 is just empty space there (apart from dash) and the added safety. If I can have the triangulation to the front bulkhead I want that to (drawing 11 in the blue book, not sure if allowed as yet for this car as I can't find it in the text).ORIGINAL: Fen Remember the steering wheel will probably be coming to meet you if you try this for real.
944 man
Neil Haughey
What ever...ORIGINAL: 944 man You werent supposed to bite John. See my earlier post about the pointlesness of nomex linings in helmets.
944 man
Do you think that a site admin should act/post in such a manner?ORIGINAL: John SimsWhat ever...ORIGINAL: 944 man You werent supposed to bite John. See my earlier post about the pointlesness of nomex linings in helmets.
Hilux
If you mean you lean back at a steep angle then seriously think `submarine` Your head wont hit the wheel, instead your gonads will hit the column.I sit high at an steep angle because I like it like that).
Very very true. Upside down or with a `yump` or violent rocking side to side you will lose the seat cushioning if its a standard seat and will `hang` out certainly on the shoulder straps by some 50mm minimum and similar when they compress the shoulder cushions so if your head is in contact with the roof when wearing a lid then lower the seat accordingly or at least be mindful of this. Its not so bad in a proper thinly padded bucket seatDon't forget that the whole situation bcomes more "elastic" under a sudden deceleration & things move much more than you might expect.
Fair enough. As the font of all knowledge we could obviously all e-mail you to get the answer for everything. Unfortunately, that would rather diminish the enjoyment of a forum. On the other hand we could give others the courtesy of assuming they might know something about something. I made the point that an FR lining to a helmet had merit - you took the opportunity to rudely ridicule my post. I suggest that most of us would agree that, in the event of a crash, a cage approved for international events would provide greater protection than a hoop required for national events. By the same measure it would seem reasonable to assume a helmet mandatory for international events is going to provide greater protection than one which would not reach that standard. In the event of a fire wearing a wet sack over your head is perhaps preferable to a nylon wig. You only get one head in this life so it is, perhaps, advisable to provide it with the best protection you can. We cant go around smashing helmets and standing in fires to see which performs the best so we rely on independent approved standards. It is reasonable to assume a helmet, approved for international events, will (generally) provide greater protection than one that doesn't meet the test criteria to achieve such certification, in the event of a crash in a car.ORIGINAL: 944 manDo you think that a site admin should act/post in such a manner?ORIGINAL: John SimsWhat ever...ORIGINAL: 944 man You werent supposed to bite John. See my earlier post about the pointlesness of nomex linings in helmets.
Game, set and match, I'd say![]ORIGINAL: John SimsFair enough. As the font of all knowledge we could obviously all e-mail you to get the answer for everything. Unfortunately, that would rather diminish the enjoyment of a forum. On the other hand we could give others the courtesy of assuming they might know something about something. I made the point that an FR lining to a helmet had merit - you took the opportunity to rudely ridicule my post. I suggest that most of us would agree that, in the event of a crash, a cage approved for international events would provide greater protection than a hoop required for national events. By the same measure it would seem reasonable to assume a helmet mandatory for international events is going to provide greater protection than one which would not reach that standard. In the event of a fire wearing a wet sack over your head is perhaps preferable to a nylon wig. You only get one head in this life so it is, perhaps, advisable to provide it with the best protection you can. We cant go around smashing helmets and standing in fires to see which performs the best so we rely on independent approved standards. It is reasonable to assume a helmet, approved for international events, will (generally) provide greater protection than one that doesn't meet the test criteria to achieve such certification, in the event of a crash in a car.ORIGINAL: 944 manDo you think that a site admin should act/post in such a manner?ORIGINAL: John SimsWhat ever...ORIGINAL: 944 man You werent supposed to bite John. See my earlier post about the pointlesness of nomex linings in helmets.
Neil Haughey
944 man
Superficially, this makes good sense, but when you look a little closer I dont think so. Allow me to explain: the difference is the fireproof lining. If youre driving your car at a track day (where youll be wearing a helmet along, possibly, with goves and boots), the fireproof lining wont make a jot of difference to you if your cabin is englulfed in flames. Similarly, if youre driving at an FIA sanctioned event, meeting all of their standards, then I dont think it will make any difference there, if youre unfortunate enough to end up in the same circumstances, because youll be wearing a nomex balaclava. If the fire is so severe that the GRP shell has burnt, then things are far too severe for a nomex lining in your lid to make a difference... Nomex doesnt burn and it doesnt melt, so it doesnt add to your problems, but it doesnt protect you for more than a few seconds.ORIGINAL: John Sims I suggest that most of us would agree that, in the event of a crash, a cage approved for international events would provide greater protection than a hoop required for national events. By the same measure it would seem reasonable to assume a helmet mandatory for international events is going to provide greater protection than one which would not reach that standard.
pauljmcnulty
Blimey - I'd have thought that Jos Verstappen was pretty grateful for the few seconds between his car catching fire and the extinguishers kicking in....[&o] Surely the point is, if you can afford it then any protection is better than none. The more layers of protection the better. Hence, I have a smoke alarm and insurance. And I back up my computer off-site in case of a fire. That's my work, I'd consider my head even more important. Why is it a problem that one person wants to add a few more seconds of protection? [8|]Nomex doesnt burn and it doesnt melt, so it doesnt add to your problems, but it doesnt protect you for more than a few seconds.
He wouldn't have looked quite so cool if the rim of his helmet had caught fire. []ORIGINAL: pauljmcnulty .... I'd have thought that Jos Verstappen was pretty grateful for the few seconds between his car catching fire and the extinguishers kicking in....
