Hi Simon
I think you are right re documenting the the damage so that people can see what has been done. It is inevitable that a 15 year old car will have needed some paint so I think as long as it is documented well that should be sufficient.
Re the paint itself, my understanding was that only water based paints can be sold (took effect earlier this year) but if a bodyshop has existing stocks of lead (?) based paints they can be used until the middle of next year at which point they too will be banned. I don't think any paint will be as good / durable as the factory paint and this isn't easily replicated unless the car is stripped back to bare metal so it can be baked fully.
The other thing to be aware of is that I understand the 964 RS was never laquered or painted with clear coat in the same way that the other 964s were (to save weight). This will make the paint less durable to chipping etc which is an issue. You could always ask for it to be painted with clear coat even though it is non-original as this is a more durable finish and may have some additional UV inhibitors to help with fading. Just make sure the paint finish underneath is good as it obviously won't polish out!! A little polish is always a good way to tell if the RS paint is original or if it has been repainted incorrectly with a clear coat.
Bit of a minefield and lots to consider but this is where a good body shop will guide you through the options. Agree that doing parts of a red car is dangerous as I have seen several cars presented in varying shades of pink depending on the quality / age of paint. Not a good look.
