Hilux
Hmm, not the answer I was hoping for....[8|][]
I've decided I want a 964 RS, so must not spend any more on my car......[]
Its a good answer but put another way .................... the pads (via the pistons) can stop the disc rotating with less effort hence they are more efficient in dealing with greater weight or momentum however I would have thought that to regain the complete advantage at the pedal the master cylinder size would need to differ accordingly for optimum effect. The same amount of heat has to be created and lost so a larger mass will allow it dissipate over a larger surface area.
For normal power the medium blacks are ok with good pads on track provided you drive properly and allow cooling off ie: dont lead or trail brake (however I managed to cook my admittedly thin Green Stuff pads on OEM discs) and absolutely stunningly brilliant with PF pads (paint your wheels black to match the dust/pitting though)
£200 for PF pads for great improvement, £15 for ATE blue (or similar) fluid or a load of money (and pads) for the big black conversion.
I am surprised the pad dims are very similar so assume they`ve probably got bigger pistons or at least one of them is increased and caliper wise they simply allow for the radius of the larger disc?? hence they look bigger but really arent IYKWIM and utilse the mechanical advantage mentioned above.
