ORIGINAL: peanut
ORIGINAL: bertelli_1
On the turbo the injectors are fired in pairs (or semi sequentially as some like to say - unless you know different from your recent work??), on the s and s2 they are batch fired (all 4 together).
I understood that the late turbo fuel delivery system was the same as the S2 (Motronic )the injectors are fired simultaneously once per crankshaft revolution (or twice per four stroke cycle)
The injectors are constantly live and are pulsed grounded within the ECU .If you look at the internal ECU schematic the injectors are wired in pairs but I thought they are all fired simultaneously on the late turbo ?
Bosch certainly made continuous modification and inprovements to the Motronic system over the 89 -92 period so you may well be right. It would certainly make sense to deliver half the fuel every crank revolution rather than have fuel hanging about in the inlet chamber for the next crank cycle
