Paul Dunster
Hi All,
I put my SC back on the road in May and have done nearly 500 trouble free miles. Came back from PCGB mtg last week and put her in the garage no problem. Saturday I went to reverse her out of the garage for a wash and she just would not start!!!
Done the usual checks there is a spark at the plugs and smell of fuel in the exhaust. With ignition on I lifted the air valve arm and you can hear the fuel pump running. My thought is the cold start valve, tested the thermo switch and this is OK. As the CSV is behind the engine it will be very difficult to get out. When I do is there an easy way to test?
Should I be looking at something easier first?
Has anyone else had the problem?
Cheers,
Paul.
Cheers,
Paul.
