help, high emmisions!
- Thread starter box 986
If you aren't getting a CEL warning, it isn't necessarily the lambda sensors Ian.
As Geoff says, best to check the MAF or preferably get a diagnostic check before jumping to conclusions.
Yours being quite an old Boxster, it could actually be a failed catalytic converter but a cat should (theoretically) be good for 100k miles unless it's suffered impact damage at some time or you're burning oil or an injector is leaking.
Jeff
I agree this simply could be a MAF issue but if you have the codes read they can identify if its a MAF or oxygen sensor - indeed, before an oxygen sensor fails they report they are getting tired but you need either a PIWIS or Durametric reader to access these codes/reports, so, its either Porsche specialist - inc OPC or buy a Durametric.
Oxygen sensor or MAF is quite cheap to do yourself if your reasonably handy with a spanner - or have an half decent mechanic as a friend.
to take it to the porsche specialist would be quite pricy, so i guess ill start out by cleaning the maf and changin the oxygen sensors, i only have 2 oxygen sensors, so that wont b too bad.
ill try to do it some time tomorrow hopefully it will solve the problem. if not, i have a feeling this is going to be quite pricy to solve.
What i forgot to say is that from the last mot test i have swapped the throttle body with a larger one in diameter, it's 6mm larger than the original, (which i still have).
but i doubt if it could be from the throttle body since the test is being done whilst idle. any ideas? i might just change to the original tb just in case.
Changing the oxygen sensors and cleaning the maf may well sort it out but you will have to pay for the test again - OK - they may retest free but if your work doesnt cure the problem they wont test again for free - and then you will need to have the codes read and pay for the retest
Oxygen sensors cost about £80.00 each
If the cats are faulty you we probably get a slight bad egg smell
So my advice is change spark plugs first,if they havent been change for a while
Try this first if still the same ,ask the technician for a code read
We run a M.O.T station & have these problems all the time
You might get away with just cleaning the MAF using a proprietory cleaner which is a fairly cheap solution to your problem. MAF's are quite expensive (c£200?) and you need to make sure that you get the correct replacement if you decide to go down that route. If it's very dirty or oily, you'd need to understand why this is happening.
The plugs on my Gen 2 Cayman are reputedly good for 4 years/50k miles but you never know. It might be worth having them out for inspection.
As for the remap, I would have thought that the DME would have adjusted the fuelling based upon the data from the MAF and lambda sensors.
The main problem as I see it is that you won't know if your fixes are successful until you get an MOT retest, so you're just going to have to have to try various things and hope for the best that in combination they work.
Good luck.!
Jeff
still failed mot on exhaust emissions! the guy at the mot didnt charge me this time, i was lucky. he said bring it back when you fix it!
going to buy oxygen sensors now, we'll see how it goes.
Really sorry to hear that Ian.
Sounds like you've been down all obvious routes without actually changing the MAF and plugs or perhaps getting a comprehensive diagnostic check at a recognised Indy or at a PC.
Maybe one of the injectors is playing up sufficiently to affect emmisions.......but that's just a shot in the dark.!
I can't really understand why it should be the case but perhaps the remap is the root cause. I presume that you didn't encounter any problems before the upgrade? I assume that fuel consumption is reasonable and that there aren't any driveabiltiy issues.
Jeff
If you are anywhere near me I would be happy to do it for you.
