A proper diagnostic check is the way to go. You have already wasted far more than the cost of a check on two oxygen sensors you didn't need. No point in throwing more parts at it, in the hope you are going to fix it, or bodge it temporarily to get through the test. You could even get a clone Durametric for about £30, which will do the job in your case.
As an example, I know from personal experience that a bad MAF will not show up on an OBD2 tester. It will give P1126/8 or P1123/5 codes, which a generic tester won't read. And if the MAF is over 50,000 miles old you are living on borrowed time, despite Porsche's quoted life of 100,000.
Just my 2p's worth.
Just my 2p's worth.
