Hi all. Just been to the 944 to fire her up and run for a bit etc but am locked out. The battery must be flat but the key doesn't appear to open the doors or boot manually.
Any ideas?
Any ideas?
My S2 had exactly the same problem a few weeks ago - left it for a couple of weeks, battery dead and none of the locks will open on the key without power. No way to open bonnet to get to charge point, doors wont open on the key, scratch head, search forums... Jacked it up drivers side, spare battery, jump leads on starter positive and negative on exhaust bracket, enough power to power the bootlid motor and jobs done.ORIGINAL: picopro19k78 Thanks for that. The locks seem dead. I wonder if they are still frozen? Both locks turn through 45 Deg but no unlocking sound and they turn very easily. I seem to remember when the battery was flat before they opened ok. I have a jump starter battery pack. If I put the positive clamp on the starter motor and the negative to ground this will give enough power to open the boot and then get the doors open and strip out the mechanism?
Hmmm. For you future reference, in on order to prevent you from having to do this again: Porsche have provided a positive battery connection (suitable for opening the hatch, but NOT for jump starting the car) under the bonnet. Under the drivers side windscreen youll see a copper connector with a blue cap on it - connect this to your positive lead and connect the negative to ground. Youll now be able to open your electric-latch hatch. SimonORIGINAL: dynaMy S2 had exactly the same problem a few weeks ago - left it for a couple of weeks, battery dead and none of the locks will open on the key without power. No way to open bonnet to get to charge point, doors wont open on the key, scratch head, search forums... Jacked it up drivers side, spare battery, jump leads on starter positive and negative on exhaust bracket, enough power to power the bootlid motor and jobs done.ORIGINAL: picopro19k78 Thanks for that. The locks seem dead. I wonder if they are still frozen? Both locks turn through 45 Deg but no unlocking sound and they turn very easily. I seem to remember when the battery was flat before they opened ok. I have a jump starter battery pack. If I put the positive clamp on the starter motor and the negative to ground this will give enough power to open the boot and then get the doors open and strip out the mechanism?
hiya pico, all great advice others have given, whats happening with yours is the same as mine ie boot wont open, if your cable has snapped or lever sheared off you still wont be able to open it ,my cable snapped six months ago and fear the same as happened again or something else related to cable, you can hear mine trying its hardest to open but it wont happen with or without key, thankfully have not had a flat battery, so for me,its off to specialists and get diagnosis, then to elliot,alisdair, or bert for relplacement parts, good luck jasonORIGINAL: picopro19k78 Thanks for that. The locks seem dead. I wonder if they are still frozen? Both locks turn through 45 Deg but no unlocking sound and they turn very easily. I seem to remember when the battery was flat before they opened ok. I have a jump starter battery pack. If I put the positive clamp on the starter motor and the negative to ground this will give enough power to open the boot and then get the doors open and strip out the mechanism?
Yes i new about the positive battery connection under the bonnet as i said in my first post, but if you cant get the doors open to access the bonnet release and open the bonnet, its not much use.... hence finding out about the 'jump lead' solution i described above as a last resort [ORIGINAL: 944 manHmmm. For you future reference, in on order to prevent you from having to do this again: Porsche have provided a positive battery connection (suitable for opening the hatch, but NOT for jump starting the car) under the bonnet. Under the drivers side windscreen youll see a copper connector with a blue cap on it - connect this to your positive lead and connect the negative to ground. Youll now be able to open your electric-latch hatch. SimonORIGINAL: dynaMy S2 had exactly the same problem a few weeks ago - left it for a couple of weeks, battery dead and none of the locks will open on the key without power. No way to open bonnet to get to charge point, doors wont open on the key, scratch head, search forums... Jacked it up drivers side, spare battery, jump leads on starter positive and negative on exhaust bracket, enough power to power the bootlid motor and jobs done.ORIGINAL: picopro19k78 Thanks for that. The locks seem dead. I wonder if they are still frozen? Both locks turn through 45 Deg but no unlocking sound and they turn very easily. I seem to remember when the battery was flat before they opened ok. I have a jump starter battery pack. If I put the positive clamp on the starter motor and the negative to ground this will give enough power to open the boot and then get the doors open and strip out the mechanism?
I'm just really confused as to why the doors won't open, needing the window removing! Obviously, with a flat battery the remote locking, central locking and boot won't work, but the doors should unlock with the key without issue? Unless they're frozen solid I guess.Ive suggested how to get into the car on the duplicated thread.
That has perplexed me too; but as others have suggested - theyve had a number of owners now and any one of them might have made a 'brilliant improvement'.ORIGINAL: pauljmcnultyI'm just really confused as to why the doors won't open, needing the window removing! Obviously, with a flat battery the remote locking, central locking and boot won't work, but the doors should unlock with the key without issue? Unless they're frozen solid I guess.Ive suggested how to get into the car on the duplicated thread.
A small point, made to avoid confusing some owners: Not all oval dash / series two cars have a non-mechanical hatch release. It was only 1989 model year cars onwards (from memory: thisll include a lot of 1988 registered cars too, of course) which had this feature. Equally it will only be these late cars which have the positive connection under the bonnet. SimonORIGINAL: robwright ...The key should still unlock the door you stick it in manually.  If you an oval dash it won't unlock the boot though...
