help please
- Thread starter Guest
ORIGINAL: zcacogp
Could be that it's not firing on all cylinders. How old are the spark plugs, HT leads and dizzy cap/rotor arm? (Sadly the last three items are pricey for an S2.)
Dont I know it Oli - you wont remember but I had to rebuild the top end of my white car when the timing chain and tensioner failed, 2 brand new cams, a recon head from EMC, water pump and all the bits that go with that lot. Will get new fuel tomorrow and see what happens.
A bit of a long shot, but there is something odd that occasionally happens to S2's when starting which manifests itself as a misfire. There have been a couple of threads about it within the last year or so, one of which was mine. Here:
https://www.porscheclubgb.com/forum/tm.asp?m=778974&mpage=1&key=starting򾖣
https://www.porscheclubgb.com/forum/tm.asp?m=727042&mpage=1&key=%F2%B1%A0%82
Are you simply suffering a worse version of this?
ORIGINAL: zcacogp
Ouch - no I don't remember it but that couldn't have been far off the cost of a decent second-hand engine, surely?
https://www.porscheclubgb.com/forum/tm.asp?m=778974&mpage=1&key=startingò¾–£
Oh loads more than the cost of a decent secon-hand engine but lets not go there.
Read the threads and most talk about hot starting, mine is from cold, not got it to run long enough since it happened to get it hot. I have a spare DME and tried that and made no difference.
Changed plugs, earth strap on battery and having pumped 5L fuel out (has about 20 L in tank) put 10 litres High octane with octane booster added. started and runs fine. So as to the cause - take your pick, my car does run rich ( how do you control mixture? I think the car has previously been chipped) and I suspect as I had only been bringing it up to normal temp and letting idle for 20 mins or so it fouled the plugs and stale fuel didnt help.
DavidL
bmnelsc
I tried to follow the mystery relay link but it wouldn't work. I found the following as one of the posts under that heading (before I saw that it was added here)... It is about third page in ...DavidL said:
RENNLIST TEXT follows
Lilja.. based on some reading I've done, that was an 'experimental' relay (basically a "flasher blocking relay") Porsche put into some 84-85 models which altered the air-fuel ratio going into the computer (pin#13 I think) for the first ~2min~40seconds or so. The same way a flasher relay intermittently blocks the power to a turn signal light (making it flash) the relay would interrupt power to a function in the DME that would alter the air-fuel ratio. (Possibly by interrupting fuel injection cycles)
This function was later provided within an updated DME relay, which is why it is not there in later cars. Some more research indicated it is indeed part number 944.615.915.01.
There is one for sale on eBay.co.uk for ~40usd.
END TEXT
Best to search up the rennlist forum entry .... following the post above there is another post that refers to a Porsche bulletin regarding fuel injectors... the fact that your car runs with it and barely runs without it suggests this may be related.
DavidL
Anyway try this
https://rennlist.com/foru...the-mystery-relay.html
