Help with noise on startup please
- Thread starter craiginuk
craiginuk
vitesse
They checked everything changed a further pulley all to no avail.
Totally baffled eventually using a stethoscope they located the noise to the oil cooler area-having initially thought it could be a balance shaft bearing.
With the cooler stripped,they discovered that the Oil Pressure Relief Valve-(OPRV) which was the original,had a thin wall steel sleeve around it which had become loose in the aluminium block port -this was oscillating as the engine warmed up causing the noise.
No spares available so had to buy the current replacement -1 part OPRV (2nd generation version) £££ gulp.
Problem solved -of course your engine may have that already but just my tuppence worth>
