ORIGINAL: Copperman05
I think the theory (or marketing hype) says that having a higher octane fuel burns more efficiently therefore improving fuel economy and performance slightly, probably more obvious in performance cars than everyday runabouts. I believe these cars ecu allows the engine to run on different octane fuel by retarding ignition, etc and can run on both quite safely. Having a chipped ecu designed to take advantage of the higher octane fuel will increase the benifits of using it at the expence of poorer performance using 95RON. I dont think its high octane fuel you need to worry about but low octane fuel, these cars arent designed to be used with less than 95ron I believe. But I've never seen lower octane fuel in this country so its not something I worry about.
I know the US have a different way of measuring there fuel and the ratings are set differently, 87RON being the equivilent of our 95RON (or something simillar) which makes things somewhat even more confusing.
Edd
