How do you fill the wheel arches on a 1986 car?
ORIGINAL: edh
What does that mean Simon?
Fit the wider front arms, hubs and rear hubs from an '87 onwards car I presume. Also just to clear up as it was mentioned earlier in the thread, all 951's have the narrower strut mount flange irrespective of track width (18mm I think).
Just out of interest OP, I notice you said your 951 has big reds fitted so any idea how these have been fitted to the '86 early offset hubs?
ORIGINAL: Richair
ORIGINAL: edh
That was done by the previous owner. I can take pics once I have the car back though.
Mick
I'd really appreciate if you could as I'm very interested to see what rotors are fitted as the biggest problem is finding a shallow enough rotor to fit...
You don't need big reds/black Rich, just use the brakes less [:D]
Lindsey sell a kit for early offset turbos with custom 2 part discs
Won't be cheap once you've bought the 17" wheels & tyres as well
Looks like 9products do them as well
http://www.9products.com/rotor-hat
ORIGINAL: Richair
ORIGINAL: edh
Was Mick's car a 951 originally though? I seem to recall it used to have the other style front?
ORIGINAL: 944Turbo
ORIGINAL: Richair
ORIGINAL: edh
Quite right. it was a 2.5L NA which was converted to a turbo. The Autofarm invoices suggest 951 front struts were fitted to the car though and adapter plates fitted to mount the brakes. Why the previous owner didn't simply buy a turbo and modify it I'll never know.
Mick
ORIGINAL: Richair
I did this modification to my track car recently when I upgraded the brakes to M030s - in addition to the front arms and hubs you also need to fit the trackrods from a later car otherwise you get a lot of toe-in....!
Mick
ORIGINAL: edh
I know, you're right Ed plus I shall be spending my pennies on posh suspension before anything else. I'm yet to fit new front rotors, but on the road I have no issues at all with the brakes even on a very enthusiastic lap of the Triangle at the weekend. I'm putting the issues experienced at the ring down to me driving like a pussy... I'll stick some newun's on though before a winter track day or two.
I think those rotor hats are for fitting m030 brakes on later offset small brembo cars though.
ORIGINAL: Masher
ORIGINAL: 944Turbo
ORIGINAL: Richair
ORIGINAL: edh
Mick
I wonder which hubs it has then, do you know what offset the current wheels are?
Tony
Current wheels are the same as my 964 17 x 7 ET55 front and 17 x 9 ET55 rear.
Mick
