bennyboy
I'm planning to sort my brakes very soon, and wondered what you chaps believe will be the best set-up in terms of what the car will be doing and costs. I do less than 5k miles a year, and as of this summer will likely be doing a track day every 6 weeks or so. I have the M030 set-up currently, with drilled disks, but I'm planning to replace the disks and pads. This is my thoughts...
1. Replace disks - ideally I'd like drilled M030 like I have now, but IIRC these are ridiculously expensive, so I may settle for solid M030 disks.
2. Pads, not sure, fast road/occasional track day compromise, any suggestions?
3. Braided hoses - any suggestions?
4. Fluid - any suggestions?
5. Cooling - I have the M030 ducts in the bumper through to the arch lining. Plan is to hook up some ducting from the arch lining to the disk, perhaps using the Lindsey Cooling plates? Suggestions?
Many thanks
Many thanks
