Hilux
get the sump baffled for sure.
Is this relevant to the turbos?
I swapped my sump and was quite impressed with the baffling. Is it insufficient? I`m surprised as it has the deep `box` with the pickup pipe low down.
I am convinced of dry sumping now as the only way to go for a motor that you are going to stress highly.
There's also a mod I read about on Rennlist that looks a good idea - is it called a windage plate? sits under the crank & easily fitted when the sump's off.
I had ordered the Windage tray
1G braking is much worse at "˜redistributing' the oil than cornering. The oil moving away from the pick up is an old fallacy; it won't happen unless you let the oil level get way below the low mark. The bearing failure looks like oil pick up starvation but it is actually caused by aerated oil and some pretty crappy oil passages in the crank.
I agree.
Braking will move your oil to the front of the pan, kick it up into the crank etc.. but, all people I asked, had failures while exiting corners under throttle.
Take the "˜but' out and then reread the sentence and think about it.
The oil sloshes forward under braking and gets severely aerated, then the engine goes through a "˜no load' period while turning in and then load it up at the apex and boom "" the combination of aerated oil, engine load and increasing RPMs take out another rod bearing.. An engine that is starving for oil while not being loaded will start to wear the bearings but not catastrophically, only once you add power will it really do damage.
Bearings don't usually fail immediately "" it can take a couple of seconds to really trash a rod bearing.
I have done bearings in two motors through racing
