Induction kits
- Thread starter Andy Tims
Andy Tims
Wiggle it & pull hard.
There is a small plastic flange at the bottom l/h corner that will snap, but you can superglue it back on & this does not seem to have an adverse effect on the fit, when you replace the cover.
The snorkel itself also needs a fair bit of pursuasion to get it out.
Good luck.
Andy
I read the fitting intructions and got cold feet. The 996 looks straightforward however the Boxster looks like major surgery is involved. Perhaps you could give me a demo at Eynsham ? A bunch of us are camping overnight a la Le Mans so hopefully I' ll see you there.
Brian
The 996 is a doddle as long as you don' t drop anything (like an old pair of socks or a handful of gravel) into the intake.
But then that would be a crazy thing to do.
Rule No. 1 - Do not work on your expensive car whilst coated in gravel.
There are probably others but this seems pretty important.
Tool Pants
non Club member but v. knowledgable
Its really up to you. I`d try as the poster above says or replace the OEM panel filter with an aftermarket one such as PiperX. You`ll get an induction note from that and it won`t mean dismantling your car.
Good luck
tony stokes
flow induction kit from Porscheshop or the Evo-v flow induction system.Surely someone must have one of these on their cars?
Tony
