thirteeneast
Firstly decreasing pressure would mean needing to re inflate so not sure where thats going???ORIGINAL: Mark Bennett
ORIGINAL: thirteeneast
I never top up my tyres either because the schrader is done up!.
Then you are seriously in danger of running with progressively decreasing pressures. The valves primary purpose isn't for letting the air out - it's for putting it in.
What do mean by "done up"? The only thing you do up is the dust cap - and the dust cap doesn't "do up" anything, nor help to retain the pressure in the tyre. It's just to do what it says - keep dust and debris away from the valve mechanism.
Secondly a Schrader valve is removable and are hardly ever wound right in from the factory and will leak from the seal.
Nothing to do with air in or out through the valve Mark.
Have a look at a Schrader
http://patentpending.blogs.com/patent_pending_blog/images/schrader_valve.jpg
Your notice the pin winds out and if its lose will leak.
Thirdly have a look at a Schrader valve key, Its not for tightening dust caps.
